Set default level for buildings (smart map)
If a particular level in a building is more relevant than others, for example the ground floor, you can set that level as the default level. When you open your smart map and go to the building, automatically the default level is selected.
If you navigate away from the building and back, XProtect Smart Client brings you to the level where you left off.
Requirements:
Smart map editing has been enabled on your Smart Client profile in Management Client.
Steps:
  1. Navigate to the building on your smart map. If necessary, zoom in.
  2. Select the building. A pane appears on the right-hand side showing you the levels of the building. The default level is highlighted.
  3. Click Setup to enter setup mode. Notice the asterisk sc_smartmap_reorder_level. It indicates where the current default level is.
  4. On the level you want to set as the default level, click the dots sc_smartmap_add_level.
  5. Select Set as default.
  6. Click Setup again to exit setup mode.
© 2018 Milestone Systems A/S
