Frequently asked questions: audio
Why is the Speakers list not available?
Some surveillance systems do not support two-way audio.For a detailed outline of the features available on your particular system, see the XProtect Product Comparison Chart on: http://www.milestonesys.com.
Can I adjust the recording volume of a microphone connected to a camera?
This feature does not exist in the XProtect Smart Client. However, you may be able to adjust the recording volume either on the microphone or through the configuration interface of the camera device that has the microphone attached. Consult your surveillance system administrator if in doubt.
Can I adjust the output volume of speakers connected to a camera?
This feature does not exist in the XProtect Smart Client. However, the Level Meter in the Audio pane gives an indication of the input level which, in turn, gives an idea of the output level.
You may be able to adjust the output volume either on the speakers or through the configuration interface of the camera device that has the speakers attached. You can also adjust your audio settings in Windows. Consult your surveillance system administrator if in doubt.
Will other XProtect Smart Client users be able to hear what I say through speakers?
As a rule, other XProtect Smart Client users cannot hear what you say. However, if microphones are located near the speakers you are talking through, it may be possible to hear you.
Can I talk through multiple speakers at the same time?
Yes, if your surveillance system has speakers attached to multiple cameras (and you have the necessary rights to access them), you can talk through all the speakers at once. In the Audio pane, in the Speakers list, select All speakers, then click and hold the Talk button when you talk.
If you have selected List only devices from current view in the Audio pane, you will not see all speakers.
Will audio from microphones attached to cameras be recorded?
Incoming audio, from microphones attached to cameras, is recorded, even when no video is being recorded.
Will what I say through speakers be recorded?
The surveillance system can record incoming audio from microphones, even when no video is being recorded. However, outgoing audio transmitted through speakers can only be recorded, played back, and exported on some surveillance systems. For a detailed outline of the features available on your particular system, see the XProtect Product Comparison Chart on: http://www.milestonesys.com.
Depending on your surveillance system, recordings can be used, for example, to prove that a XProtect Smart Client operator gave an audience specific instructions through speakers.
Do I get an indication of my voice level when I talk through speakers?
Yes, in the Audio pane, the Level Meter indicates the level of your voice. If the level is very low, you may need to move closer to the microphone. If the Level Meter shows no level at all, verify that the microphone is connected and correctly set up.
© 2018 Milestone Systems A/S
