Change order of levels in buildings (smart map)
Requirements:
Smart map editing has been enabled on your Smart Client profile in Management Client.
Steps:
  1. Navigate to the building on your smart map. If necessary, zoom in.
  2. Select the building. A pane appears on the right-hand side showing you the levels of the building.
  3. Click Setup to enter setup mode.
  4. Click and drag the dotted area sc_smartmap_reorder_level to the correct position. In doing so, any associated cameras and custom overlays stay with the level.
  5. Click Setup again to exit setup mode.
© 2018 Milestone Systems A/S
