Add cameras to buildings (smart map)
After creating a building and adding levels, you can add the cameras. If a default level has been specified, the cameras are associated with it. Otherwise, the cameras are associated with the first level. You can change this and associate the cameras with any of the levels in the building.
Requirements:
Smart map editing has been enabled on your Smart Client profile in Management Client.
Steps:
  1. Navigate to the building on your smart map. If necessary, zoom in.
  2. Click Setup to enter setup mode.
  3. Click sc_smartmap_add_camera_icon Add a camera.
  4. Click again on the location where you want to position the camera. A dialog appears.
  5. Select the required camera and click OK. For each camera you want to add, repeat steps 3-5.
  6. To associate a camera with one or more levels, right-click the camera and select the required levels.
  7. Click Setup again to exit setup mode.
If no levels are selected, the camera is visible on all levels.
© 2018 Milestone Systems A/S
