When you add a camera to a building, by default, the camera is associated with the default level if one has been specified. Otherwise, the camera is assigned to the first level. However, you can change this and associate the camera with any other level, or several levels at the same time.
More facts:
If you readjust the boundaries of the building, so that it no longer covers the camera, the camera is no longer associated with the building.
© 2018 Milestone Systems A/S
