Add plug-in elements to smart map
If the MIP plug-in can be configured with GPS coordinates in Management Client, it will be positioned on the smart map when you add it. If not, you must position it yourself in its exact geographic location.
  1. Select the view that contains the smart map, and then click Setup.
    Tip: Before you add the MIP plug-in element, it's a good idea to zoom in to the location on the map. This makes it easier to accurately position the plug-in element.
  2. To add a MIP plug-in element, on the smart map toolbar, click Add a plug-in element, and then select the plug-in element.
  3. To save the change, click Setup to exit setup mode.
© 2018 Milestone Systems A/S
