Add plug-in elements to buildings (smart map)
After you create a building and add levels, you can add the MIP plug-in elements. If a default level has been specified, the MIP plug-in elements are associated with it. Otherwise, the MIP plug-in elements are associated with the first level. You can change this and associate the MIP plug-in elements with any of the levels in the building.
Requirements:
Smart map editing has been enabled on your Smart Client profile in Management Client.
Steps:
  1. Navigate to the building on your smart map. If necessary, zoom in.
  2. Click Setup to enter setup mode.
  3. Click Add a plug-in element.
  4. Click again on the location where you want to position the plug-in element. A dialog appears.
  5. Select the required plug-in element and click OK. For each plug-in element that you want to add, repeat steps 3-5.
  6. To associate a plug-in element with one or more levels, right-click the plug-in element and select the required levels.
  7. Click Setup again to exit setup mode.
If no levels are selected, the plug-in element is visible on all levels.
© 2018 Milestone Systems A/S
