Send a view between displays
- In the Views pane, right-click the relevant view (or in the Cameras pane, the camera in the view).
- Click Send View To and then select where you want your view to display.
If more secondary displays are available, they will be numbered.
- Click Link window to synchronize your view in the floating window with that of your main view. If you link the floating window, the corresponding timeline is not displayed in your floating window but is included in the timeline on the main window.
- To close a separate view window, click the Close button in the right corner of the window:
If a view is sent to Primary Display or a Secondary Display the title bar is hidden. To display the title bar and get access to the Close button, move your mouse to the top of the view.
Any hotspots, carousels, Matrix positions, still images or HTML pages included in the view will work as usual in a floating window.
© 2018 Milestone Systems A/S
