Available functionality depends on the system you are using. See the Product comparison chart for more information.
When you configure general scheduling and archiving, you can specify certain properties for many cameras in one go. Either in order to speed up things, or because the relevant properties are shared by all cameras rather than being specific to individual cameras.
Note that you can specify the properties for Online Period, Speedup, Notifications (Email and SMS), and PTZ Patrolling individually for each camera.
Template |
The template can help you set similar properties for cameras and reduce the time you need to spend on changing settings if you have multiple cameras connected to your system. Example: You have 20 cameras and want to change the recording path, archiving path, and retention time for all cameras. You can enter the settings you want to use once and then apply the template to the 20 cameras to make all cameras have the same settings. |
Apply Template |
Select which cameras you want to apply the template for. Use one of the two Set buttons to apply the template. |
Camera |
The name as it appears in the Management Application as well as in clients. |
Online |
Select the required profile (for example Always on) for the online schedule for the relevant camera(s). Specify a camera's online periods by creating schedule profiles based on:
You can combine the two options |
Select the relevant profile for the e-mail notification schedule for the relevant camera(s). Specify a camera's e-mail notification periods by creating schedule profiles based on periods of time. Example: Mondays from 08.30 until 17.45, shown in blue: |
Select All |
Click the button to select all cameras in the Apply Template column. |
Clear All |
Click the button to clear all selections in the Apply Template column. |
Set selected template value on selected cameras |
Apply only a selected value from the template to selected cameras. |
New schedule profile |
Create a new schedule profile of any type by clicking the Create... button. |
SMS |
Select the required profile for the SMS notification schedule for the relevant camera(s). Specify a camera's SMS notification periods by creating schedule profiles based on periods of time. Example: Mondays from 08.30 until 17.45, shown in green: |
PTZ Patrolling |
Only available for PTZ cameras with patrolling, the continuous movement of a PTZ camera between a number of preset positions. Select the required profile for the PTZ patrolling schedule for the relevant camera(s). Specify a camera's patrolling schedule based on patrolling profiles within particular periods of time (example: Mondays from 08.30 until 17.45), shown in red: |
© 2019 Milestone Systems A/S
