Milestone ONVIF Bridge
The Milestone ONVIF Bridge is comprised of the following components:
- Milestone ONVIF Bridge server
- Milestone ONVIF Bridge 32-bit plug-in for Management Application
- Milestone ONVIF Bridge 64-bit plug-in for Management Client
The following image shows a high-level view of the interoperability between an ONVIF client, the Milestone ONVIF Bridge, and XProtect VMS.
Note: Milestone recommends that you install the ONVIF Bridge server in a demilitarized zone (DMZ).
XProtect VMS
ONVIF clients
- An ONVIF client connects to the XProtect VMS via the ONVIF Bridge server through the Internet. To do this, the ONVIF client needs the IP address or domain name (domain/hostname) of the server where the Milestone ONVIF Bridge is installed, and the ONVIF port number.
- The ONVIF Bridge server connects to the management server to authorize the ONVIF client user.
- After authorization, the recording server starts sending H.264 video streams from the cameras to the ONVIF Bridge server.
Note: If a camera supports multiple streams, only the default stream is sent.
- The ONVIF Bridge server sends the video as RTSP streams to the ONVIF client.
- If available, the ONVIF client user can pan-tilt-zoom PTZ cameras.
© 2019 Milestone Systems A/S
