Once you have added the number of devices and cameras you want to add, your system sets up storage for you. Storage is the location to which your system saves recordings. By default, your system chooses the location with most available disk space.
When the system has finished configuring storage, you are given the option to automatically add new cameras to your system as they are detected on the network. Enabling this allows you to set up your system so that any devices or cameras are automatically set up for you in the future as soon as they are connected to your network. Note that not all devices and cameras support automatic discovery.
If your device/camera does not show up automatically after you have connected it to your network, you must add it manually.
If a device/camera has been added to your system previously and you removed it, the device cannot be discovered automatically and you must add it manually.
To go directly to XProtect Smart Client once you have completed the wizard, select the check box in the bottom-left corner of the wizard page.
© 2019 Milestone Systems A/S
