Select a view
You can select a view from the Views pane on the Live and Playback tab. If views have been assigned shortcut numbers, you will also be able to select a view by using keyboard shortcuts.
  1. In the Views pane, select either Private or Shared views.
  2. In the relevant group, select one of the available views.
If neither the pane nor the shortcut is available, check the pane's availability in the Settings window.
© 2018 Milestone Systems A/S
