Display text on one Smart Wall
You can copy text directly from a text editor into a tile in your Smart Wall.
Requirements: Your text editor must support drag and drop operations to perform this procedure. If your text editor does not, follow the steps described in Display text on more than one Smart Wall.
Steps:
- Select the view that contains your Smart Wall overview.
- In your text editor, enter the text you want to display.
- Select the text and drag it to the tile in the Smart Wall overview where you want to display it. The built-in text editor appears.
- Review the text, and make any changes required.
- Click Save.
- To edit the text after you save it, in the Properties pane, click Edit text.
- In the Smart Wall view item, click and select a display option, for example Primary Display. For more information, see View live or recorded content in XProtect Smart Wall.
As an alternative, you can add text to a view item and then send it to your Smart Wall. This is described in Add text to view item or Smart Wall.
© 2018 Milestone Systems A/S
