Display carousel on Smart Wall
If you are using XProtect Smart Wall, you can display carousels.
Requirements: You have added a carousel to your view as described in Add carousel to view or Smart Wall.
Steps:
  1. Go to the view item that contains the carousel.
  2. In the toolbar, click More > Send to Smart Wall and select the Smart Wall, monitor, and the tile where you want to display the carousel.
  3. In the Smart Wall overview, click view_options_dropdown_19x8_Dark_SCREENSHOT and select a display option, for example Primary Display. For more information, see View live or recorded content in XProtect Smart Wall.
© 2018 Milestone Systems A/S
