Display map on Smart Wall
You can send maps to your Smart Wall, so that the map is displayed in the Smart Wall overview.
Requirements: You have added a map to your view as described in Add map to view or Smart Wall.
Steps:
  1. Go to the view item that contains the map.
  2. In the toolbar, click More > Send to Smart Wall and select the Smart Wall, monitor, and the tile where you want to display the map.
  3. In the Smart Wall overview, click view_options_dropdown_19x8_Dark_SCREENSHOT and select a display option, for example Primary Display. For more information, see View live or recorded content in XProtect Smart Wall.
© 2018 Milestone Systems A/S
