Add map to view or Smart Wall
You can add existing maps to views or create new ones.
- Click Setup to enter setup mode.
- In the System Overview pane, drag the Map item to a position in the view.
- In the Map Setup window that appears, select either Create new map or Use existing map. A triangle next to a map name indicates that the map might have one or more sub-maps. Sub-maps and the elements they contain are also added.
- In the Name field, enter a name for the map. The name will be displayed in the title bar of the position.
Tip: If you leave the Name field blank and click Browse..., the Name field displays the name of the image file you select.
- Click Browse... to browse for the image file to use as a map.
- Click Open to select image file.
- Click OK.
- Click Setup again to exit setup mode.
- To display the map on your Smart Wall, see Display map on Smart Wall.
© 2018 Milestone Systems A/S
