View recorded video using independent playback
You can only use this feature for ordinary single-camera positions, not for hotspots, carousels, or Matrix positions.
- Move your mouse across the camera that you want to view recorded video for. On the toolbar that appears, click the Independent Playback button.
The independent playback timeline appears:
- Drag the timeline to select the time containing the video that you want to view.
- If you want to view recorded video for the selected time on all the cameras in your view at once, on the toolbar, click the View recordings from selected time on Playback tab button:
. This displays the Playback tab with all cameras synchronized to the time you have selected.
© 2018 Milestone Systems A/S
