Depending on your surveillance system, you can create, edit and delete patrolling profiles:
You and other users can see the new patrolling profile in the PTZ menu.
Create patrolling profiles
The new patrolling profile is added to the Patrolling profiles list. You can now specify the positions and other settings for the patrolling profile.
Note that the system only saves your changes when you click OK. Until then you can cancel all your changes.
Delete patrolling profiles
To delete an existing profile, select the profile and click .
Specify positions in a patrolling profile
PTZ presets are defined by your administrator or, depending on user rights, you can do this by clicking the Manage PTZ presets button.
The camera uses the PTZ preset at the top of the list as the first stop when it patrols according to the patrolling profile. The PTZ preset in the second position from the top is the second stop, and so forth.
Specify the time on each position
When patrolling, the PTZ camera by default remains for five seconds on each position specified in the patrolling profile.
To change the number of seconds:
Specify an end position
You can specify that the camera should move to a specific position when patrolling ends. You do that by selecting an end position on the patrolling profile.
You can select any of the camera's PTZ presets as the end position, you are not limited to the presets used in the patrolling profile.
You can also choose not to specify an end position at all, but to keep the default setting: No end position.
Add or edit PTZ presets
If you find that the existing PTZ presets you can select from do not suit your needs, you can create additional presets for the camera or edit the existing ones.
You return to the Manage patrolling profiles dialog box.
© 2018 Milestone Systems A/S
