Smart map settings
Enter the Bing Maps key or Google Maps client ID or key for the Bing Maps API or Google Maps API that you use.
Note: You can edit these settings only if your administrator has allowed you to in Management Client.
Name
Description
OpenStreetMap geographic background
Specify whether the OpenStreetMap service can be used as a geographic background. If you select Unavailable, XProtect Smart Client does not display it as an option.
Alternative OpenStreetMap tile server
To use a different tile server for your OpenStreetMap than the one specified in the configuration, enter the server address here.
Create location when layer is added
Specify whether to create a location when a user adds a custom overlay. For more information, see Add or delete a custom overlay on smart map .
Bing Maps key
Enter or edit the private cryptographic key that you generated for the Bing Maps API.
Client ID for Google Maps
Enter or edit the client ID that you generated for the Google Static Maps API.
Private key for Google Maps
Enter or edit the private cryptographic key that you generated for the Google Static Maps API.
Remove cached Smart Map files
Smart map saves to the cache on your local computer so that it can load faster. Use this setting to specify how often you want to remove the cached files.
© 2018 Milestone Systems A/S
