View live or recorded content in XProtect Smart Wall
Your Smart Wall displays both live and recorded video depending on the tab you are standing on.
User rights can prevent cameras from displaying video on your Smart Wall.
Steps:
- To view Smart Wall content in the current window:
- Expand the Smart Wall folder in the Views pane.
- Expand the Smart Wall and select the monitor. The Smart Wall overview appears showing, for example, video content.
- To review content without interfering with what is being displayed on the Smart Wall for others, click Disconnect Smart Wall monitor. Changes you make, for example adjusting the time slider, are reversed when you reconnect.
- To view content in a separate window:
- Open the view where you have added your Smart Wall.
- In the view item that contains the Smart Wall, click
in the upper right corner. - Select Send View To and select a display option.
For more information about display options, see Viewing Smart Wall in separate window (explained).
© 2018 Milestone Systems A/S
