Viewing Smart Wall in separate window (explained)
The following table describes ways to view Smart Wall content in a separate window or secondary display.
Option
Description
Primary Display
View content in full-screen on the display that you're currently viewing. Smart Client remains open behind the Smart Wall content. You can minimize or resize the window.
This option is useful when you want to focus on the area that the Smart Wall covers. For example, when you want to watch the front parking lot after security has lost track of a suspect inside the building.
Secondary Display
View content on another display, and continue viewing Smart Client on the current display.
This option lets you keep an eye on your Smart Wall while working in Smart Client. For example, you can continue to monitor the parking lot while you export video of the incident.
Floating Window
View content in a floating window on the display that you're currently viewing. You can maximize or resize the window.
For example, this option is useful when you want to display content from multiple Smart Walls. You can watch the parking lot and the roof at the same time.
For more information, see Viewing live or recorded content in XProtect Smart Wall.
© 2018 Milestone Systems A/S
