Search recorded video
You can search recorded video using the Sequence Explorer, the Recording Search pane, or Smart Search pane.
On the Playback tab, you can use the Recording Search pane to quickly search for recorded sequences or bookmarks for a single selected camera or for all cameras in a view. Alternatively, you can use the Smart Search pane to search for motion in one or more selected areas of recordings from a particular camera.
Smart search cannot be used for video from fisheye lens cameras. Depending on your user rights, access to smart search may be restricted.
© 2018 Milestone Systems A/S
