Log in and out
- Open XProtect Smart Client.
- Specify your login information, and click Connect. If a problem occurs during login, you may receive an error message.
- If you have logged in before, you can restore the views used during the last session. Depending on the configuration, the XProtect Smart Client may ask you if you want to restore the views:
- Main view: If you select this option, the view that you used last time in the main window of XProtect Smart Client is restored.
- Detached views: If you select this option, the view that you used last time in a floating window of XProtect Smart Client is restored. Only available when connecting to specific Milestone surveillance systems.
- To log out of the XProtect Smart Client, simply click the Log out button in the XProtect Smart Client title bar.
If you encounter a second dialog during login, you need additional login authorization to get access to the XProtect Smart Client.
© 2018 Milestone Systems A/S
