Buildings on smart map (explained)
Buildings on the smart map are depicted as polygons with four edges. Once added, you can adjust the dimensions, angles, and size to match the actual shape and position of the building.
If the building is a multistory building, you can start adding levels and add cameras to the individual levels. This allows you to navigate the cameras inside the building, level by level.
To help you illustrate the interior of a level, you can add custom overlays to levels, for example an image illustrating a floor plan. For more information, see Add floor plans to levels.
Buildings are automatically given a name, for example Building 4. Milestone recommends that you change the name. This will make it easier for you to distinguish buildings from one another.
smartmap_building_editmode
© 2018 Milestone Systems A/S
