Edit buildings on smart map
Once a building has been added to the smart map, you can change the name of the building, and adjust the position, the size, dimensions, and angles. You can also add, remove, or change the order of levels.
Requirements:
Smart map editing has been enabled on your Smart Client profile in Management Client.
Steps:
- Navigate to the building on your smart map. If necessary, zoom in.
- Click Setup to enter setup mode.
- Click anywhere inside the building. A blue-ridged border indicates that you can edit the building.
- To rename the building, go to the top of the right-side pane and click
. Change the name and click
. To cancel, press Esc. - To adjust the corners, click and drag them to a new position.
- To add or remove levels, see Add or remove levels from buildings.
- Click Setup again to exit setup mode.
© 2018 Milestone Systems A/S
