Floor plans and cameras in buildings (explained)
To help you visualize the interior of the levels in a building, you can add floor plans as custom overlays. With a floor plan in place, it is easier to precisely position the camera. For more information, see Add floor plans to levels (smart map).
The cameras you position are associated with levels, not custom overlays. If you delete a level inside a building with cameras and a custom overlay, the cameras stay in their geographical position, but are no longer associated with the level. However, the custom overlay is deleted together with the level.
If you change the order of a level, both the cameras and the custom overlay stay with the level. The cameras maintain their geographical position.
© 2018 Milestone Systems A/S
