Settings window (explained)
The Settings window lets you control which features and elements, for example, language selection, joystick setup and keyboard shortcut setup, you want to use on each of the tabs. For languages where your normally read and write from right to left, you can choose to enforce a visual left-to-right interface if needed.
Open the Settings window from the application toolbar:
In this section
Application settings
Panes settings
Functions settings
Timeline settings
Export settings
Smart map settings
Keyboard settings
Joystick settings
Access control settings
Alarm settings
Advanced settings
Language settings
© 2018 Milestone Systems A/S
