MIP plug-in elements are customized additions to your system. They are available only if they are added on your surveillance system. Examples of MIP plug-in elements: sensor monitors, alarm systems, fire detection systems, and so on.
You can add MIP plug-in elements to a smart map in their actual positions in your environment. This gives you a good overview of your surveillance system and can help you respond to a situation.
You can also add MIP plug-in elements to building levels within smart map, as described here: Add plug-in elements to buildings (smart map).
After you add a MIP plug-in element to a smart map, you can manage the plug-in functionality from within smart map by using the right-click menu. The functionality in the right-click menu depends on the MIP plug-in.
In this section |
© 2018 Milestone Systems A/S
