In setup mode, you can create groups and views, and specify which cameras should be included in each view. If a top-level folder has a red background, it is protected:
You can still access any views under the protected top-level folder, but you cannot create new views or edit existing views under it.
Your ability to edit views and groups depends on your user rights. Basically, if you can create the view or group, you can also edit it. If in doubt, contact your system administrator.
In this section |
© 2018 Milestone Systems A/S
